non abs to abs conversion
stevenr816
932
Phoenix,AZ
i've looked for write ups but cant find any.
i know you will have to change over the hard lines, soft lines, spindles (easiest way), actuator, computer.
but what about the wiring harness? is that built into the body harness?
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
My abs sucks dick, every time it rains ive got to deal with it coming on when its not wanted
stevenr816
932
Phoenix,AZ
suprabad said:
I don't have that problem. Maybe there's something out of whack with your abs.
i like abs, and dont like abs. it depends on what im doing etc......
btw, if you have ever read the owners manual on any abs car, it say
"ABS does not stop the car any fast, it only lets you keep control of the car in most situations, and may double the stopping distance depending on climate....."
this is why i want to put a switch on to override it somewhere, and so when your road racing, or whatever you can take it off.
but on the streets, its usually amazing
supradavenz
LOL HIES!
Apr 1, 2006
159
AUCKLAND, New Zealand
i too was going to do this to my 7mge-7mgte conversion but i decided against abs. it looked semi easy in my eyes. my car came with the ABS optional loom so all the plugs were there just needed hubs, lines, ecu, abs unit and the ??sensor for the gearbox??
Some of our jdm chassis here didnt get abs optional harnesses how about you guys in the states? do they all have that harness?
stevenr816
932
Phoenix,AZ
i sure hope mine has the built in harness if not i'll find a pin out and try making my own harness :naughty:
jayhall: it won't come on unless it senses lockup, sounds like it's working fine in the wet...
I never have mine come on unless I STAND on my brake pedal...
stevenr816
932
Phoenix,AZ
looks pretty easy if you have all of the sensors
IF you have all the parts, do it...
It's going to be a lot of work, so I'll worn you now... You'll have to mess with a LOT of items (gotta run the computer's wires, swap out spindles, ect ect ect)
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
this just might be the reason there hasn't been a write up or anyone 1 doing it lately =P.
