Due to the bizarre behavior of this problem, the explanation of what I did that led to the ignition breaking is a bit long. The jist is, I'm not getting spark at the coil pack. If you don't want to read the long story, I highlighted a few key points in blue and you can scroll to the bottom for the final problem description. Any help would be greatly appreciated.
I recently changed my CPS because my old one was leaking oil. Over Easter weekend I installed the new CPS, got it started, set the timing, etc.
I then buttoned everything up and then decided to do a couple other things while in the engine. The coil pack ground wire was stretching across the cam valley and connected to the bolt stud on the other side, so I decided to move it so it wasn't in the way. I moved it and verified it was a good ground with a volt meter. I also had to fix my FPR lines as the shop I took my car to last somehow created a fuel leak that wasn't there before (That's another story). Anyhoo, so I re-did the fuel lines leading to the FPR and fuel rail and thought I was done. I attempted to start the car, and it wouldn't start.
At this point I wasn't sure what broke it. I checked the fuel system, and fuel was being delivered. I moved back the coil pack ground wire to the location it was at before. I then checked the igniter (per TSM), and that appeared to be ok. I then noticed that only one of the coil sets were creating spark. I checked the packs per the TSM and they appears to be ok. I decided to put back in my old CPS, but that didn't help either.
A friend of mine is a Toyota mechanic, so I called him up and he came out this weekend to have a look. He checked everything as well, and couldn't find a problem. We took the coil pack out and we undid all the connectors, then reinstalled it, and the car started. We found that very odd and were both troubled we didn't find a smoking gun.
*** This is where I broke the ignition ***
I put in the new CPS again, car still started and I set the timing, buttoned everything back up, and the car still started. I then decided to relocate the coil pack ground wire again. Looking at the engine from the front of the car, I grounded the wire to one of the big screws for the cam cover, as this moved the wire out of the way of everything else. I verified the ground was good, then attempted to start the car. It wouldn't start, and the symptoms were just like before. Evidently, this is what broke it before. I moved the wire back to where it was before (Stretching across the cam valley to the bolt stud on the cam cover) and it still wouldn't start - no spark.
This makes absolutely no sense to me. How can moving the coil ground to another location make any difference as long as it's a good ground? I haven't been able to determine if any of the coils is sparking as I don't have anyone to crank the car while I look for spark, but I will say at least two of the coil pairs are not generating spark.
Anyone ever see this before?
