no acceleration... well hardly
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
Recently i had my car sitting around and for some reason when i push the accelerator down it hardly accelerates... feels like its starting off in 3rd or 4th... its auto by the way, what can be wrong?? loose throttle cable??? i have to "manually" shift it from l, 2 and D, to it can decently accelerate.....let me know guys
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
That's easy. You're driving an N/A like the rest of us...
Haha, just playin, I'm actually not sure as I have no idea how autos work. But good luck, I'm sure someone can give you some pointers
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Limp mode? Plugged cat? is the CEL on?
how does it run other than seeming gutless? any smoke? and backfiring or misfiring?
you could check to make sure something didnt go wrong with your throttle cable by having someone push the pedal to the floor, then checking to see if you are getting full rotation of the throttle body valve.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
NO to any of the following can be cause for a tranny overhaul.
Does it accelerate good with the shifter in the low position??
Yes? Then the torque converter is probably ok.
When you manually upshift to 2nd, does it still pull hard??? Yes?? then the clutch packs are probably ok.
When you move it to 'D' (OD off), does it keep pulling hard???
Then with OD engaged does it keep on going???
Yes???
Then it sounds like your problem is either in the automatic operation of the valve body, or the solenoids, or the transmission computer.
Best to have a reputable (meaning one that won't rob you) tranny shop check it out. They may be able to repair it without a complete overhaul.
But...be aware that most shops don't want to do "repairs". They just want to overhaul them. That is because if it screws up after they "fixed" it, you'll get pissed off. So a complete overhaul will fix everything, and you won't get pissed, and everyone is happy. (except you, because it will cost you about $1500)
supramacist
1,501
The Grassy Knole
Get a TSRM and I mean now. It is your new best friend.
Jervis Mcstabby
Puddin Pops!
Jun 21, 2006
151
Where Indeed, CA
Alex91Mk3 said:
I have to "manually" shift it from l, 2 and D, to it can decently accelerate.....let me know guys
I had the same problemon my N/A tranny, and after I pulled it out, I found that my tranny plug wires were cut. I'd suggest checking the terminal connections, and maybe the solenoids. I can't find the terminal diagram right now, but I'm pretty certain I found it on the TSRM online. Check on there right quickly :icon_bigg
