new to toyota
karlmk3
336
thornton
ok i know im gonna get bashed for this but i need help go easy today it my bday so im getting a 1986.5 supra for my bday i have looked at supra since i was a lil kid i love them i know a lil bit but i have been looking for a 1jz for the last week i am trying to figure how hard this swap is and what i will need the one i am looking at come with moter turbos ecu harness tranny but then i am looking at doing the 2jz swap as well some advice on this one is it more diff which moter do you preffer i am 22 this is not gonna get riced out i am restoring this car from i ricer i cant stand that s@&t thank any help greatly appreciated and if u know where i can get a 1jz id greatly appreciate it jarco dosent sell them anymore it seems like no one does
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
welcome to SM..!
this forum section is only for introductions and pics of your ride, and some info on yourself...
but, to swap in a 1JZ, you'd need a late 89-92 crossmember with motor mounts, or buy 1JZ pre 89 conversion mounts from www.bicperformance.com..
as long as you have all the wiring and necessary hardware, it's a straight forward swap...
you can swap in an r154 from a USDM 87-92 Supra Turbo with a JZ bellhousing, or if you have a w58 (non-turbo 5 speed tranny) and can get ahold of a 2JZ N/A bellhousing off an NA MKIV Supra or an SC300 itll bolt right up, however a w58 will probably hold up to 400 max (mine is holding up fine with a 7MGTE BPU), but those bellhousings are RARE...
karlmk3
336
thornton
ill post pic of the car as soon as i pic it up its scary it pretty beat up but i know this car has some good potential ok so the 2nd prop i am having is findin the 1jz i want any one know anywhere it seem like they are hard to get
RazoE
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
try Kaizen at http://kaizen-hps.com/or Driftmotion at www.driftmotion.com
they're vendors on this forum...
oh for your other question about 2JZ's, it'll mount up and the same tranny's will fit with as the 1JZ with the same hardware, but wiring is MUCH harder, and the rear turbo will not fit without modification to the firewall, so most end up going single, but it's still possible to keep the stock twins, also it's MUCH more expensive.
karlmk3
336
thornton
one last question on wiring in a 1jz ecu how hard is it to due the wiring would it be easy to just relocate the ecu to driver side some where or ....
karlmk3
336
thornton
ok so on the 1jz will i be able to keep both turbos? im used to playing with hondas so this is a whole diff world to be i have done a few jdm swaps but on a honda its nothing 4 bolts out 4 bolts in well the wireing did suck though
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Yeah, the 1JZ engine harness is a couple feet too short, because they were designed for RHD cars. You will have to extend the harness or relocate the ECU, Both difficult tasks.
karlmk3
336
thornton
ok thanks for all the info i looked at a 1986.5 today well it is gonna haunt my dreams it was rusted through under the driver side i could see the ground where the spare tire was just a huge whole there where no fenders to speack of and well the engine bay rusted so bad i thought the engine would fall out so im gonna look at a 1989 on friday hopefully in better shape none of these cars are running all have blow head gaskets im hoping that is just an issue with the 7m moter ?
RazoE
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
yeah it's an issue with the 7m motor, but it also usually caused by the 7m owner..
change out the headgasket, correctly prepare the surface, and torque down using the proper lb/ft of torque, keep her full of coolant and it should outlast the car...
