new problem? bad wheel bearing?
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Well a new problem has popped up, i think it is a bad wheel bearing, just thought i would run it up the flag pole to see what other people think,
I hear a high pitched grinding like noise from the front passenger side Wheel, it's not constant and comes and goes, some times worse then others, i have visual inspected it and the hub portion of the brake disk is become discouloured, my guess is from extreme temperatures, the discouleration is all close to the center and there is non on the Disk it self, it does not look as if the caliper is rubbing but something inside (the bearing)
your thoughts?
Supracentral
12
If the hub is discolored that's all you need to know.
Stop driving it before the wheel comes off when you are driving.
Disassembly time. You need to get in there and see what is torn up. If you are lucky, the spindle survived it.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i'd use the one on the front clip or another used one.... thats what i did and no problems here;; a few years ago i replaced a different one through toyota and it just cost wayy too much :x
91 mK3
Laaaaaaag
Aug 22, 2006
242
Hayward, Bay Area
here is a simple way to find out if its the wheel bearing. just jask up the side thats making the noise, spin the wheel with one hand and put your fingers on the springs. if ou feel any vibaration, then its the wheel bearing for sure.
