new oil
mkIII2jz
15
tenino
i just put some amsoil in the 7mge and with a 6 cylinder engine restore bottle
omg the differnce
now it revs so much freer and it sounds cripser and the get up is compleately
differnt
its more punchyer lol
87mgte
87 Turbo Targa
Sep 9, 2007
536
Sequim
omg the differnce
differnt
Well let us know how long the engine keeps up its new "get up".
jdub
Feb 10, 2006
10,730
Valley of the Sun
Amsoil is a good oil...depending on what weight you put in, it should work well. Any improvement you see is due to using this oil.
I would not have use the Engine Restore though, it's snake oil ;)
AJ'S 88NA
2,419
Florida
I used Engine Restore in my coffee maker and it made it work so much better, so it is good for some things.:)
mkIII2jz
15
tenino
the old oil was regular 3000 mile oil
what!!!!!
I have used it in every thing i own and it still performes to it name
jdub
Feb 10, 2006
10,730
Valley of the Sun
Me or the OP JJ? ;)
Engine Restore is full of copper and lead in an uber high viscosity base carrier oil. These are the same two metals you see showing on an oil analysis as "wear metals"...as mentioned, it's a placebo effect. You believe, and you see what you want to see.
My advice? Dump the snake oils and run a quality synthetic oil (or even a quality dino oil)...your motor will run just as well and you're not thickening your oil up for no good reason.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Heehee...all so true ;)
You been flying to ORD lately...sounds like one of their lines :biglaugh:
