new dyno number precision 7475 built motor and meth
quake
toyota tech
Apr 13, 2005
619
r.i.
so went back to the dyno today after my recent build up' new changes are as follows.
meth kit dual nozzle with 250psi pump
found and fixed boost leak in intercooler pipe
readjusted the bov tighter
os giken tripple
motor has wiseco pistons, eagle rods, 74mm .81ar, 264 cams custom, mild head port, 1000cc's, ets 3 row, q45 throttle body, custom ffim, custom 3.5" exhaust, tial 44
739rwhp and 636tq @ 29psi 93 octane and meth peak timing 11deg uncorrected smoothing 3
691rwhp and 579tq @ 29psi c-16 peak timing 19deg uncorrected smoothing 3 (old number)
714rwhp and 615tq sae smoothing 3
644rwhp and 540 tq sae smoothing 3 old number
scan dyno sheet soon maxed out the map sensor in my stinger ems so it will go up for sale. Will scan dyno sheet soon here is a link to the old sheet thoughts welcome..
quake
toyota tech
Apr 13, 2005
619
r.i.
thanks guys was strange just going to shell to fill up. Last year i spent $150 on just 9 gallons of c16
quake
toyota tech
Apr 13, 2005
619
r.i.
hvyman;1673569 said:
First time you filled up in a while? Just dont forget to take the thing out lol :yikes:
this car is a daily unless it is actually snowing i usually do 20k a year, and people yell at me for it lol
---------- Post added at 06:59 AM ---------- Previous post was at 06:53 AM ----------
---------- Post added at 07:00 AM ---------- Previous post was at 06:59 AM ----------
GrimJack;1673682 said:
Nicely done. I'm interested in why the C16 number is lower than pump + meth, that seems whack.
quake
toyota tech
Apr 13, 2005
619
r.i.
well for one i had a boost leak back then and a damaged piston i did not know about from and overboost on pump. However after about 10 back to back pulls on meth the intake plenum is cool to the touch. Still have things to fix like no rubber lines anywhere as they expand and for the first time ignition break up. Had to gap down to .020. Also i want more up top past 7k rpm. Mind you timing is down 10 degrees and still made more.
quake
toyota tech
Apr 13, 2005
619
r.i.
jmcboost;1674428 said:
Quake, didn't you use to have an ACT extreme clutch setup? Did you swap it out because you maxed it out?
yep
---------- Post added at 09:09 AM ---------- Previous post was at 09:07 AM ----------
suprahero;1674436 said:
Congrats Quake. Very impressive numbers for 93 octane and methanol.
thanks now post my sheet for me if you can, cant get a clear pic. I do have the file also but you need to download the software from dynojet
quake
toyota tech
Apr 13, 2005
619
r.i.
lower graph was c 16 and 20 deg timing
other was meth and only 10 deg max with ignition break up
RacerXJ220
Interdimensional
Abalama
Nice numbers. I wish I could hit that at 29PSI with my 74mm. My 185,000+ mile block might need a replacement just to hit 650 on pump/meth.
