Not sure if this is correct area because its boost related (thinking as an afterthought... )
So, background (for those that don't know), my car is in the shop and getting tuned/upgraded since June last year. The car has a HKS Fcon Vpro 3.3 (7M chipped) and the boost controller is a HKS EVC-S.
Car runs fantastic, however, on the dyno doing the final tune, etc, the car wont boost past 5 psi (tried both a 10 lb and 14 lb spring in the Tial wastegate). If it does it will spool and then jump to 19 psi (turbo cut is set at 19 psi currently to protect the turbo). Makes awesome power.. however.. there is NO BOOST control. Tried changing out the EVC-S solenoids.. no effect.
Thinking that this may be because of either the wastegate is too small (need a 60 mm??) or a manifold issue (I don't think its manifold though).
Anyone have an ideas what would cause this in your opinion? In research mode now to see what the potential issues may be.
Boostcreep occurs when your wastegate cant flow enough to keep up with the engine, which is why I am wondering if the 44mm Tial Wastegate is too small...
(keep in mind... no cams, no head porting at all.. stock head. The NA-side of my tune has the engine running far better than any 7M I have seen so far... )
(This is just in case your wondering what's in the car now... not part of the question, but good background)
7MGTE (Wiseco pistons, polished crank and rods, Cometic 1.2 MLS Headgasket) - engine runs like a top!
3" vband DP mated to a HKS 3" catback exhaust with twintip mufflers
No head porting or cam upgrades
HKS Longrunner Manifold (used bought from Leftynridge here on the forums). Lots of reconditioning needed, is now ceramic coated.
Tial 44 mm Wastegate (bought from Leftynridge as well along with a SP6267 .84 ar turbo that is dead)
SPracing 6262 .68 ar DBB Turbo (new and on the car sitting on a 1.75" spacer, 4" intake, 3" vband hotside)
1000 cc ID Injectors
HKS Fcon Vpro 3.3 standalone *7M
HKS EVC-S boost controller
90 MT MK3 ECU (swapped in as my Vpro connects to a 89+, not pre 89)
- kept the ECU for idle timing and AC functions
DM 7MGTE Intercooler upgrade (custom piping done though as the CXRacing version doesn't quite fit properly...)
