need quick help.. int lights & door switches
Finnon
701
South Shields, Tyne & Wear ENGLAND
suprra_girl said:
our mirrors don't have lights... just mirrors hehe
boot light never worked for some reason, couldn't figure it out, bulb was good but just light doesn't go
at that stage dome/door lights worked
so that bolt in the kickpanel that bolts a fuse type thing on to the bottom of the fusebox is the ground?
your bootlight not working could be the switch as it is part of the lock mecanism. mine broke and when i took the interior panel off i found the switch part had moved and so was always turned off
Finnon
701
HellsLegion said:
Ill trade you some USDM mirrors for some turn signals.
Why does everywhere else int he world like our shit,a nd we love theis lol.
i sold my euro turn signals to someone in the states as a deal to get me clear turn signals about 2 years ago lol... does anyone have a pic of the vanity mirror with a light in?
I bet you guys have a lighted drivers door lock bezel aswell.
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
Yeah we have lighted bezels, lighted mirrors, fade-out lights when you close the door (courtesy lights), digital climate control and so on.
Luxo-mania.
No digital dash though. Oh well... Digital dash blows.
EdgeSupra
506
New Jersey
Luxo-mania.
Hahahaha, and LOL @ the word 'boot', thats great :biglaugh:
My dome lights dont light up either, but the red open indicators do. Gauge lights dont light, and climate control only lights when headlights are off.
I'll check the dome fuse first, then if thats good, take the small panel off the lights and check the ground?
And the fuse for gauge lights is fine, shoudl I take out the cluster and check everything out behind there?
-Justin
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
the other thing i noticed is that the little red picture of doors open is also missing on the dash... i really dunno how to fix this lol
oh and i saw where that intergration relay object is... what PITA to get to... and what should i do with it?
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
Have you checked for corrosion/missing hardware on the bolt/threads where the door switch grounds to the chassis? Sorry if this is a repeat. Eric
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Kai said:
Sounds like the Integration Relay is at fault. It controls all of that. Either that, or you've got a bad fuse/fusible link.
Where is that Relay at? I have the same problem and my windows dont wanna go down.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
supradan22 said:
The integration relay is on the back side of the j/b with the main fuse cluster in the driver's side kick panel.... it's a PITA to get at. Take out the driver's seat and remove the plastic kick panel.
