Need help with these plugs.
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
Just wondering where these plugs connect to ?? its on the wiring harness.
I think this one connects to the trans wire.
anyone know ?
Justin
Speakers?
Spokane, Wa
the black blue wire with the brown plug is for your starter.
I think the top one connects to the tranny somewhere, but I'm not sure.
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
Thats what i thought the brown one was for.
The little one, the first pic, i can't figure that one out. Didn't the trans had three plugs connected to it ?
Ok, looks like the pics are all taken on the driver's side, right?
The last one I THINK is for the tranny sub-harness.
Brown connector you figured out, first one depends a LOT on where it's located as they use that connector all over the place...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
brown - starter
white - tranny ABS sensor IIRC
gray - A/C, Coolant tank, CSI
BTW - that's one hell of a clean harness, is that new?
92nsx
2,957
Clearwater, MN
Brown and white plugs are correct^^^^
The gray one is for the EGR temp sensor, only found on a cail. spec car. I also have it ;) It comes down between runner 3 and 4 correct, with those other plugs and the grounding points.
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
i m pretty sure the first pic plug doesn't plug to anything on the car cause i m pretty sure i didn't unplug it from anything when i took out the old wiring harness.
Yes it is a new wiring harness. Got it from Elmhurst Toyota. It ain't cheap, cost me 492 something with tax. Grey Plugs :biglaugh:
