Need help with startup
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
Started this bitch for the first time in over a year today. Idle was revving from about a thousand to 2k with a code of 41 (TPS). I shut it down. Looked around. tightened this and that. Start up: the same, ran it for a few minutes shut it down. Checked oil and coolant. Go to start it up again....nothing....the starter soleniod is click but the engine's not turning over......about to source out some narcotics to keep from taking a pick-axe to something.....CAn anyone give me an idea, a clue, some help?
shaeff
Kurt is FTMFW x2!!!!
11
Around
grab a 19mm socket/ratchet and turn it over by hand. if it turns, then you didn't seize it. :)
as for your clicking starter, make sure you have all good grounds. if that doesn't work, tap on it lightly with a metal rod or hammer.
-shaeff
