Need help on fuel pressure
mk3turbo
176
4
michigan
Ok I have a sx fuel pressure regulator, 255high pressure fuel pump with the 12volt mod done on my mk3. When i try to lower my fuel pressure with the sx regulator, the lowest it goes down is 50psi, thats with the whole screw out of the regulator. Is this normal with the 12volt mod????
8,900
Well, that pump is gigantic in flow compared to stock. Most also bypass the J-tube or drill out the orifice for more return flow.
mk3turbo
176
4
michigan
But is this normal with the 12volt mod? On my buddy mk3 supra with just the 255fp without the 12volt mod can be turn lower than mines.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
It is not the 12v fuel mod brother i belive that your fpr is bad. It might be something simple as a diaphram change. Good luck
mk3turbo
176
4
michigan
I bought my sx regulator about a year ago but the car sat 90 percent of the time in the garage when i installed it. Im gonna put my buddy aeromotive regulator on and see what happens. I can still raise the pressure with the sx regulator though.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
Most likely its your FPR. I have no problem adjusting down below 30psi on a aeromotive A1000 which is able to use dual -10 ORB feeds and support 1000hp (IIRC). The base pressure isn't even supposed to be able to go below 40psi according to the site.
OneJArpus
2,798
7MGTE, stock FP is 33 to 40 PSI
7MGE, stock is 38 - 44 PSI
Just got done reading this on the repair manual.
Could be the cheap FPR causing the issue of 50 PSI when fully adjusted out.
I have 550's 12v mod and a driftmotion aeromotive FPR and i can set it low as well. Currently at 35 psi with vac line off.
Are you setting the pressure with vac line on or off? It shouldd be with vac line off BTW.
mk3turbo
176
4
michigan
I set it with the vac off. I got the sx brand, not the cheap xs brand off ebay. SX brand is a really good brand like aeromotive.
8,900
Did you read the part about the J-tube? It is a built in restriction. And you have a much larger pump, and are running full speed all the time. Of course you have high pressure. There may or may not be anything wrong with your aftermarket regulator. If it is designed to lower fuel pressure drastically in addition to raising, then maybe it does have a fault.
8,900
It used to be worse. For me it started in the late 90's with things like AOL car chat. When I left AOL in 01 or so, and went to the forums, I took my grumpiness that I devolped on AOL with me. It has taken a decade to tone it down.
mk3turbo
176
4
michigan
This J-tube is the little tube that is connect to the block under the intake manifold right? Shapes like a J or U for the return line.
mk3turbo
176
4
michigan
Ok thanks man, problem solved. I cut off the restrictor off the j-tube and was able lower the pressure below 50psi. I set it at 39psi. What do you guys usually set the fuel pressure to for a good tune?
8,900
Feels good to figure it out by using a diagnostic method, albeit a somewhat crude one, than to buy parts until it is fixed, don't you think? It does for me. Fuel pressure is in the book. Mine is stock.
mk3turbo
176
4
michigan
Yeap.
