Need help instructions for configuring Greddy Rebic LC
drjonez
the motor city
www.4cefed.com
Rebic LC manual
(right from the manual. strange English)
LC is multi functioned fuel controller.
LC functions as "fuel increase" for high boost with TVVC.
LC functions as "Boost cut" cancel, "speed cut" and "rev limiter" cancel.
LC is possible to make fuel control according as any tuning situation or any Intake-Exhaust efficiency to the normal turbo charged machine.
With
1. power switch
LC/on Rebic LC function kicks in
Normal/ON normal computer funciton(without rebic function)
off same as above
PW LED- when switch is at LC/ON, the LED comes on.
Blue dial- for fuel control
LC CAL LED- when the rebic is working properly, it will not light up.
Min-Max indicator- shows the injector duty. 12 light means 100%
Installation
1. make sure the power switch is at OFF before you install.
2.connect the harness between the ECU and LC.
3.connect monitor harness
4.turn on the switch to LC/ON
Installation is done
Setting
1.Rebic LC functions will kick in when the RPM reaches the kick in point
2.Rev your engine to 6000RPM and check if the lamp on the indicator lights up. When the lamp comes on and LC function kicks in, it might have little shock(vibration), but it is no problem.
3.you can change the fueling by +-30% with the dial. at the setting Zero, it will be -30%, and at dial 10, it will be +30% more fuel.
4.make sure to use air/fuel meter not to lean your engine.
DONE!
