Need help identifying a fitting on my FFIM
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
I posted this in my build thread, but I figured I would have more luck here.
The manifold is a Ron R. unit with an ISC provision. There is a welded AN fitting beneath the 'HKS' elbow which has got me stumped (right before the throttle body). I have no idea what it's for. It sits right above the alternator so I doublt I'll be able to utilize it anyway.
Any ideas?
Mo87NA
8
Upstate NY
That's what I was thinking, but I'm not positive.
Maybe someone with the same set-up will chime in.
Mo87NA
8
Upstate NY
Could be, but the idle up for the power steering is a pretty small line. This fitting is at least a -6.
Usually, that's used to hook up the a vacuum manifold for items that need vacuum (the stock setup uses a fitting on the front of the intake manifold)
Mo87NA
8
Upstate NY
Thanks, Poodles.
There honestly is not much room between the fitting and the alternator as you can see from the picture. Theoretically speaking, I could use that fitting to connect a vacuum block for additional vacuum sources correct?
