Need help choosing
redmk3
Idaho
I want to do a R154 5 speed conversion on my 88 turbo, but I want to know if I can use a 86-87 ecu and can I also use a 89-92. Does the wiring harness has to be for R154 or can I use W58 harness?
shaeff
Kurt is FTMFW x2!!!!
11
Around
For the manual transmissions, there is no harness. ;) Only wires are for ABS sensor if you have it, and the switch for the backup lights.
You can use any manual transmission with any harness, even an automatic harness. :)
