need help. aem v1 question.
gsxr141
1,158
9
rochester
hello all. just a quick aem question.
is there any way to feed the stock tach a signal from the aem so that the tach works?
i have sti coils installed, so everything under the hood that WOULD have sent the signal is gone.
thanks in advance......
Funkycheeze
Grease Monkey
Jul 3, 2009
163
Calgary
You would need to piggyback a signal from one of the ignition outputs on the ECU that you are using. I don't think it has any other provision for tach output.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
The AEM can output a tacho signal, but I never got it to work on my original 1991 Turbo Tacho. I bought an aftermarket (Autometer) unit that does the job pretty well.
toyotanos
2,841
Coon Rapids, MN
So get a little one! Mine is a 3.5" one that's pretty close the the OEM tach in size. I too, didn't want the giganto-tacho so I got the lil guy.
Funkycheeze
Grease Monkey
Jul 3, 2009
163
Calgary
Did some looking - the V1 does indeed have the ability to output a tacho signal on a low side output. You might need to fiddle with the settings and run it through a tach adapter box MSD 8920 to make it work properly with the factory instrument cluster.
gsxr141
1,158
9
rochester
thanks funkycheeze. i might end up wiring in a small aftermarket tach, seeing as my car now revs past what the stock tach reads. ;)
