Need a little Help....
AJ'S 88NA
2,419
Florida
I think I'm going to get a group buy together for IJ and JJ Action Figures.
That's why you guys are so grumpy, you know too much lol.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
Tire Shredder said:
you need to jump the diagnostic block with a paper clip or wire (as per the TSRM) when checking the timing so the ECU knows what the static (base) timing is correctly set..
damn it.... :nono:
<Pointing at him...JJ>>>> Yep he's Grumpier cos he knows more :D
The more you squeeze into a brain the less room for warm fuzzy happy thoughts!
AJ'S 88NA
2,419
Florida
Well I'm older than both of you it's just I don't know as much so I'm only half as grumpy.
Wait a minute......I don't think that came out right........:nono:
Big_Rob
12
Gardnerville
So you guys think that will help me get my power back? I did notice that it does a herky jerk when i let out the clutch normally, and when I get on it it starts loosing power at 3500-4000 rpms...
Frank Rizzo
478
Fixing your girl's car
If I were you, I wouldn't post in this thread again until you set the ignition timing. These guys just bent over backwards to explain how it works, and it only takes the better part of 10 minutes to accomplish.
Where's that group buy? :)
