na to turbo swap ecu question.
chefma70
404
Florida
i have my harness run through the firewall into the glovebox.
the harness has 7 plugs. i know 3 of them go into the ecu,where do the other 4 go?. i cant find out where the other 4 plugs plug up to.
chefma70
404
Florida
by the way my car is a 1987 yellow plug n/a and my harness is a 91 turbo grey plug would that have anything to do with it?
Letsride
183
NC
Yea like everyone has said its not compatible unless you want to replace the dash harness as well (PITA). I will swap harnesses with you if you want as I have the same problem....I have the yellow plug harness but need the gray.....LOL.
Just PM me if I can help.
chefma70
404
Florida
lets trade harnesses,pm on the way. whats the condition of your harness?mines is in really good shape i want to be sure yours is the same.:icon_bigg:icon_bigg:icon_bigg
noel your the best!!!!!! i dont know what i would do without you ..lol.
intercooler is fully assembled and i could turn the key right at this moment but the harness is wrong!!!!!:nono:
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Side question, I have a yellow plug harness (brand new). Plan to use it in the future, not sure in what car, and i like the yellow plug cuz AEM EMS is like $500 cheaper for yellow plug. Assuming the car is an 89+ how hard would it be if i cut the plugs out of my 87 parts car, and cut the harness plugs off of an 89+ and made a jumper harness for the car harness? Just soldering, or are there different wires?
Letsride
183
NC
You would have to match the wires from both EWD's. A lot of work and not all may match up. Its easier just to use the right harness....
lewis15498
Sep 28, 2008
1,397
Like I said, 87-88 EMS ~$1250, 89-92 EMS ~$1750. Plus I got the harness for a steal. If Making a jumper harness is a PITA, i dont really care if it saves me ~$1000 long run.
all you need to do is get the connector and re-pin them. which finding out which wores need to go where might take a bit but you wont need to do any soldering. all connectors come apart to where you can remove the wires from the connectors with out cutting the wires.
lewis15498
Sep 28, 2008
1,397
Now thats a good answer! Thank you sir!
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
wheres my intercooler for $20 lol
