NA-T oil cooler
mecevans
1,295
M-bay, cali
i need help with selecting parts for an oil cooler/ remote filter. since its NA-T it does not drain into the pan. i already have a DM oil line kit to feed the turbo. i want to use a canton or similar 90 degree rotating adapter because of the better clearance. then whatever degree bends to get it to the frame rails for routing. rubber Aeroquip or similar lines, but not braided. i have no idea about sizing the cooler. i live in Monterey and its about an average of 60-70 if its not raining or overcast. power goals are 350hp tops. im ready to order this stuff asap but need guidance!
Canton 90 degree oil filter adapter
socketless hose 90 degree
aeroquip socketless black -10 AN
permacool 1791 filter bracket
thanks!
supra90turbo
shaeff is FTMFW!
MA, 01440
Man speaks the truth! I agree. You can score an FC RX7 cooler pretty cheap sometimes, and that's a large cooler with thermostat built in!
If you know someone into RX7's have them find you one on the forum. The ones on Ebay are a rip-off
