na cams
dumbo
1,913
Albera, Too Far North
It's a downgrade, from personal experience. Put a turbo on my ge, than later put a gte intake cam in(exhaust is the same both engines). Gte is better.
Not an upgrade (really, think about this, why would Toyota have produced 2 different cams if it would have saved them money to make one?)
It will come on power faster, but fall on it's face in higher RPMs. Area under the curve is reduced meaning while it might FEEL a bit faster on the bottom end, you're slower overall...
It's a sidegrade from the dark days.....
It shifts the powerband to the left of the dyno chart spooling sooner so it gives a punchier midrange where most DD's drive but getting asthmatic on the top end.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
I can't find the thread with the dyno sheets either, but if I recall correctly, the engine started falling flat on it's face around 5,000 RPM....give or take a few hundred. Basically, if you've seen a dyno sheet for the N/A and notice when the power started falling off WAY before redline; the GTE with N/A cams will start having the power fall off at the same time.
You just end up shifting the power band to the left with an N/A intake cam.
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
What about doing that in reverse? Since an n/a cam is not the best for a GTE, would a turbo intake came help a n/a in higher rpms?
ValgeKotkas
2,224
Over the pond
If it starts dying at 5k, then IMO that's anyway the last shifting point. And if no overall hp's/tq's are lost....
I guess I won't change cams when going NA-T then :)
Thanks.
Hell, if you went with a larger turbo, it's just coming online at those revs, you're just going to hurt you in the end...
