N/A Gas milage.
DegreE
500
Memphis & Miami
My GE with 236k original miles.
Original headgasket.
New NGK sparkplugs
New Toyota Plugwires
New Radiator
New Toyota Waterpump
New Toyota Thermostat
New Toyota Timingbelt
New Toyota Tensioner
New Toyota Drivebelts
Valvoline 20w50 conventional engine oil.
WIX oil filter.
Tokico Blue struts
Eibach Pro-kit
Homemade Autozone Intake.
Gutted catalytic converter, 100% stock exhaust.
Stock sawblades wrapped in Toyo Proxies and kept @ 40psi.
I'm getting 200 miles to the tank on 87 octane from Shell. with 10% Ethanol. A/C was not used during this tank and revs never passed 4k.
How big is our fuel tank exactly? And what is your average MPG.
For some reason, I feel like I should be getting better MPG.
Post your milage, mods, engine oil and what fuel grade you use.
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
Your mileage sucks. I get 300+ to a tank and my car is modified. Part of your problem is your ridiculously thick oil. Why are you running 20w50? Are you using new plugs?
Edit: I just saw the new NGK spark plugs.
Mileage: 23MPG average
Mods: Numerous
Oil: Pennzoil Platinum 10w30
Fuel: Shell V-Power
DegreE
500
Memphis & Miami
Yes, they are new plugs with 3k miles on them, I pulled them out the other day and they look perfect.
Reason for the oil is becasue the previous owner (original) has been using that oil since it hit 100k and I'm scared to use a different viscosity now. I've had the car since December 07.
It has a very slight rear-main seal leak which I plan on fixing when I replace the clutch for my NA-T conversion.
Finnon
701
South Shields, Tyne & Wear ENGLAND
that oil is for like old ford pinto engines etc.
im uk basd and i get about 80 miles to £20 petrol. its priced at £1.15p per liter. if you can work it out as im tired just now so off to bed. then youll have how many liters to 80 miles (uk liters tho) then how many liters the tank holds etc etc
my car isnt the healthyest though so probably could do more mpg
edit: i just remembered. the pinto engine was found in ford cortinas, sierras and transits etc. dont think its related to the old ford pinto cars u guys got over there.
DegreE
500
Memphis & Miami
benchwarmer;1040691 said:
You know, if you're planning on going NA-T you really should freshen the motor up first. Have you done a compression check?
I've been meaning to for the longest. I've been too lazy.
The car feels good. Pulls nice for a N/A (past 4k lol). And doesn't misfire.
DegreE
500
Memphis & Miami
IJ.;1040714 said:
I used to easily get 360 miles to a tank when my car was NA at highway speeds.
How old is your 02 sensor?
Hmmmm I completely forgot a new o2 sensor will improve mpg. Its prob the original. lol
I don't remember seeing anything about an o2 sensor in the maintinence records. (yes, I have records of all the work ever done to the car including all oil changes, tires, brakes, ect...)
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
i get bad mpg too i just rebuilt my motor, it has great compression, and doesnt leak oil or miss or anything, i do good to get anything over 220 in a tank.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
get a new o2 sensor then... lol
and i can easily get over 350 on the highway... but 75% of my driving is street/city, so its 'ok', i can get almost 300-350 in the city...
rebuilt engine
new plugs and wires
5w30 castrol
gutted cat, and intake that eliminates the silencer. and that was on 89 octane, i wanna see what my milage is on 87.
DegreE
500
Memphis & Miami
What o2 Sensor would you guys recommend?
Does autozone sell a exact OEM replacement? I really don't want to cut & rewire a new one.
Also, I've read some people say to change the fuel filter and others say don't. wtf should I do?
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
i got a denso one from my local autoparts store and it had a butt connector that plugs into the stock connector.
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
If I drive smoothly I can get around 400 miles to a tank, I do mostly highway though. When I'm not driving highway I usually make 330 mile to a tank.
I have HKS cat back, test pipe, CAI, and NGK Spark Plugs and Wires.
I personally don't like much from Autozone. I haven't tried but NGK seems to have quality parts, other than that, I would go Denso. Good luck!
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I get an average of 22 mpg with more than a dozen floored accelerations per fill up. Mixed city/highway. 281,000 miles on rebuilt original motor. 31,000 miles since full rebuild.
I have rather complete records for the car and no mention of an O2 sensor being replaced. Could very well be the original.
Ma70.Ent
1,871
NJ
My city mileage is around 260ish but that's sometimes with a heavy foot and windows down.
My highway mileage is around 340ish but that's not using the full tank, having windows down, and cruising at high speeds (massive drag!).
Oh, and I'm automatic.
