My New Baby
Bluechulappa
839
hOUSTON
www.houstonareasupras.com
Sside;1037527 said:
Brought the Supra Home today :(, Something is wrong with it :(. The engines runs smooth but the car wont go over 20 mph :(. It just stays like in 1st gear soo I am sad. Hmm, It supoosely needs some vacum sensors and stuff so I will do some more thing to it 2morro to see if I can get it running any better :(. Im exhausted and fustrated. Grrrrrrr
Ha congrats! You own a supra... Welcome to many nights of exhaustion and wondering if its worth it..
JDMMA70
2,550
Houston
hah i never wonder that, i knew what i was getting into before i got the car :icon_razz i was prepared haha
Sside
554
Houston
I believed I would get my supra, drive it and be like WOw this is the most fun I have ever had driving. Yup, I found out once again. Nothing in life is easy :(.
But hey, the Ac Works Yippie woop woop. I now have a car with good Ac for summer and that sounds like a speed demon due to the turbo going shhhhhhh zzzzzzzzzzz..But they dont know the limit is 20 mph Muahahahahahha. Wait that sucks for me not them
JDMMA70
2,550
Houston
Do you have a boost leak? Either that or your turbo is dying
Sside
554
Houston
Ugh BlueChu, I hope So. I woke up at 6 am and berely got home to rest. Well I been running around looking for sensors, and doing stuff to it like a new clutch fan because the engine was overheating. Boost Leak? Turbo Dying? NOOOOOOOOOOO!!!! not yet :(. Iono, I have never had this problem with a car. Its automatic, soo right after 1st gear the engine goes into this stage like if its neutral, I accelrate and nada (nothing) and I am sure the Turbo is going because once you let go of accelrator you hear that zzzz or wait do you hear it when you accelrate it a little bit then let go. So im not sure if its a Turbo problem, Engine, Sensors. :( AHHHHHHHH. :aigo:
JDMMA70
2,550
Houston
Sside;1037583 said:
Ugh BlueChu, I hope So. I woke up at 6 am and berely got home to rest. Well I been running around looking for sensors, and doing stuff to it like a new clutch fan because the engine was overheating. Boost Leak? Turbo Dying? NOOOOOOOOOOO!!!! not yet :(. Iono, I have never had this problem with a car. Its automatic, soo right after 1st gear the engine goes into this stage like if its neutral, I accelrate and nada (nothing) and I am sure the Turbo is going because once you let go of accelrator you hear that zzzz or wait do you heart when you accelrate it a little bit then let go. So im not sure if its a Turbo problem, Engine, Sensors. :( AHHHHHHHH. :aigo:
Turbo Dying
Just listen for the death whine its quite noticable.
http://www.94supra.com/videos/death_whine.wmv
Two things will and can cause this.
Boost Leak
Intercooler Hoses i had the lower hose from the turbo blow off and it shot out black smoke out the tail pipe. The car will spool the turbo but you wont be going anywhere.
Knock Sensors
They are on the side of the block screwed in you have two of them.
But before you do anything check for codes.
Code 34 is Turbocharger Area Problem
Code 52 is Knock Sensor
You have to jump something in the diagnostic box.
http://www.cygnusx1.net/Supra/TechTips/engine_error_codes.aspx
Sside
554
Houston
JDMMA70;1037593 said:
Turbo Dying
Boost Leak
Knock Sensors
Omg, Thanks a Million..... I have not even see the links but Yup, Black Smoke is coming out exhaust. Ima go ahead and better study what you are talking about, Just felt the need to thank you right away for the time you spent looking for links and thinking bout this issue. :)
JDMMA70
2,550
Houston
Hey its no problem im happy to help ive been through this many times. Replace your spark plugs they are fouled by now
Most common ones to blow are the hose from the 3000 pipe to the throttle body, lower intercooler hose from the turbo to the intercooler, check your hoses for any small crack and replace it and get tbolt clamps make sure everything is extra tight. My guess is the lower intercooler hose.
Sside
554
Houston
Supposely I needed a new Water hose, I ordered one but it was too short soo I told dude to use the old ones the car had already. So I could atleast bring car home. I think all the hoses were in bad shape. I am not sure if we are talking about same hose. I have never had a turbo :(. Or a fast car for that matter lol. But I think we are aiming at the right problem, unless its the turbo dying because my car does sound alot like that mk4 in the vid. :(. If my turbo dies I will suffer a great deal. And once again thank you, Just so you know, I wont stop thanking you ever muahahaha lol :p.
JDMMA70
2,550
Houston
Oh you won't suffer there are used turbo for sale up here all the time im sure the people here in town will help you if you just ask. Replace all your hoses, I've got a spare lower ic hose that I kinda patched up if you want it. Bluechulappa will help you too just talk to the houston guys
