My MAFT-PRO THREAD!
born2drv
1,199
Burbank, CA
OK so I spent the past hour or so tuning the car....
1. First of all, I think I read somewhere that once the car is warmed up, there is nothing that controls the idle anymore correct? My car idles at around 1200-1350rpm and I can't figure out why. Also my A/F ratio at idle is at 10. If this is 100% not MAFTPRO related, what could it be?
2. I have a AEM Uego 5-in-1 wideband. When I sit in the car with the key in the accessory position (car is not running), I get a flat reading of 18 on my gauge (off the scale)... but when I look at the Tuner Pro software, my A/Fs are all over the place? This is what it looks like:
(big picture: http://www.born2drv.com/albums/maft/maft1.jpg)
Even when I'm just cruising around, and the A/F ratio is nice and flat on my gauge but it is still fluctuating a lot in the tunerpro software? Looks like this:
(big picture: http://www.born2drv.com/albums/maft/maft2.jpg)
What gives????
3. Between shifts, my A/F ratio jumps very high and sometimes I get a backfire, how do I correct this?
4. In the Tuner Pro software, I don't get all the same tuning sections in the Tables/Functions groups like I do on the MAFTPRO. For example, PT tracking,
and things like this are not in it. Is it because I'm using the .bin, .asd, etc files from 4.60 and not 4.65? Where can I get the files for 4.65 or how do I get them from the MAFTPRO unit? When I download it, it does not update my version on the Tuner Pro software.
I think that's all the questions I have for now :)
drjonez
the motor city
www.4cefed.com
you're a bit confused- warm idle is closed loop w/the O2 sensor, albeit @ a slower rate than cruise.
your idle is dang high. look for codes, etc. idle A/F should be right around stoich.
just an FYI- you'll probably need more than an hour or so... ;)
What gives????
sounds like the ever common-grounding issues. make sure you have the MAFT pro's purple wire connected to the WB's ground.
whaht are you running? AFC mode? translator mode? speed/density?
this should help...
http://www.mgnta.com/Documents/MAFTProSetup/Setup/
born2drv
1,199
Burbank, CA
malloy - i'm running v4.65 on the translator, but i'm using the 4.60 files as instructed from the update of 4.65.
drj - thanks for all the info, i'm running in speed density mode... do you think the backfiring is caused by the A/F reading issues?
anyhow looks like i got a lot of work to do :) i'll bump this thread again when i get a chance to look at all these issues
born2drv
1,199
Burbank, CA
not crazy lean, it just spikes about +2 to +4 A/F when I shift.... and I am not driving the car WOT at all...
for example i was cruising around the city at 14AF and it popped at 17.5 or so when it backfired during a 2>3 shift... and when I was on the highway merging on i accelerated and shifted from 4>5 and it went from 15AF (was already kind of high) to 18 and backfired really loud. i wasn't pushing it that hard though.
now i've got it tuned much better so the AFs stay around the 11.5-13.5 range, but it still jumps +2 to +3 AF between shifts.
born2drv
1,199
Burbank, CA
This is my setup by the way ....... couple people emailed me asking how I had it configured, so I thought I would post it here:
TunerPro Bin Data Export
Source File: tpro4600.bin
Source Definition: TPro4600.xdf
Constants
Vehicle Select 00
Number of Cylinders 6
Displacement 3.00 Liter
Airflow Source 0x00 Select
Manifold pressure source 00
Density Comp Source 0x00
Barometer Comp Mode 00
Frequency Out Mode 0x04
V Out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 3 Select
Freq In Mode 11
Aux 1 mode 00
Main Scale -10.00
Volts Out 1 Setpoint 2.45
Volts Out 2 Setpoint 3.53
Afterstart enrichment 0.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
Freq Out Max 0
Timing Monitor, Base Adjust 0.00
Timing Monitor, Correction 1.27
AFR Tracking, Enable delay 0.00 Seconds
FE Smoothing 00
Boost control TPS Spool 2.40
Boost control RPM Spool 2400 RPM
Boost control TPS Start 2.80 Volts
Boost control PSI Start 7.00 PSI
Boost control DC% Start 30.00 Percent
Boost control PSI Set 15.00 PSI
Boost control PSI Aux 10.00 PSI
Boost Control Gain 6.80
Boost Control DC% Start Aux 30.00 Percent
Boost Control Max RPM 0.00
AFR Min TPS 4.90
AFR Min RPM 3488
AFR Min MAP 148.29
AFR correction lean limit 10.00
AFR correction rich limit 10.00
AFR correction gain 4.00
AFR Aux % 0.00
TPS Enrichment 0.00
TPS Decay 0.60
Throttle Body Size 6
TPS MAP Max 104.06
MAP Enrichment 0.40
Boost Enrichment 0.40
MAP TPS Min 0.40 Volts
MAP RPM Min 640.00
MAF Limit TPS Threshold 0.00 Volts
MAF Limit 0.00
MAF Limit / KRPM 0.00 Grams/Sec
Flags
Tables
AFR Tracking
AFR AFR
2000 3000 4000 5000 6000 7000 8000
A/F Ratio 13.60 12.50 11.50 11.50 11.50 11.50 11.50
VE table
MAP(Kpa) RPM
00 400 800 1200 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000 7600
320 78.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
300 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
280 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
260 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
240 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
220 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
200 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
180 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
160 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
140 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
120 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
100 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 87.0
80 70.0 70.0 70.0 75.0 80.0 82.0 83.5 88.5 82.5 81.5 80.5 79.0 78.0 77.0 77.0
60 66.0 62.0 62.0 67.0 71.0 75.0 78.5 82.5 71.5 70.5 69.5 68.0 67.0 66.0 66.0
40 62.0 56.0 56.0 58.0 63.0 64.0 68.0 69.5 60.5 59.5 58.5 57.0 56.0 56.0 56.0
20 57.0 48.0 48.0 51.0 53.0 55.5 58.5 59.5 51.5 49.5 48.5 47.5 47.5 47.5 47.5
00 44.0 44.0 44.0 47.0 48.0 49.5 51.5 53.5 46.0 44.0 43.0 42.0 42.0 42.0 42.0
AF User Tune Hi
RPM
Percent 15.0 15.0 15.0 15.0 15.0 17.5 17.5 17.5 17.5 20.0 20.0 20.0 20.0 20.0
AF UserTune Mid
RPM
Percent 10.0 12.5 15.0 15.0 15.0 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5
AF User Tune Lo
RPM
Percent 20.0 15.0 10.0 5.0 7.5 7.5 7.5 10.0 10.0 10.0 10.0 10.0 10.0 10.0
Aux Triggered tune
Percent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Air Temp Correction
degrees
-40.00 13.00 41.00 62.00 82.00 103.00 129.00 173.00 315.00
Pecent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Spark WOT
RPM
2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
Degrees 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00
Spark Aux
RPM
born2drv
1,199
Burbank, CA
Regarding my backfiring, I've driven around a bit more and I notice this is what happens... I'll be driving along at whatever AF (say 12-14) and then I let off the gas to shift... the AF will climb pretty quick and if I don't shift quick enough, it will go to 18+ and backfire. Especially if I'm driving med-high throttle and let off the gas, the wastegate releases, AF climbs and I get a big pop if i don't shift quick enough.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
My tunerpro wouldnt play back at all with 4600.bin & .xdf after i went 4.65, then I went back to 4400 on tuner pro, and It all works again, but.....my a/f readings and timing monitor readings are all whacko on playback , timing can read 80- 108 deg advance sometimes, others 30. I cant wait for new tuner pro, this one sucks ass, I'm happy with the pro though. If you can tell me how to copy a whole window and post it like that, I'll show ya, can't seem to figure that out. Dangit.
chriso
Supranian
Bay Area, CA
Ken,
When you have the graphs on the screen....hit the print screen button, then paste that into a paint program and save it as a jpg, gif or bmp, then you can post it on here.
Thanks a lot Yosef for the setting information. I had mine running a little today and dialed in a couple of the low range settings pretty close I think. I still have a lot of work to go but hopefully with the info you supplied, I can get her running a little better since our setups (other than the turbos) are almost identical.
Btw, are you running the timing monitor part yet or not and which VE table are you using (#1 or 2)?
Thanks again.
Chris
born2drv
1,199
Burbank, CA
Be careful, those settings are not really that great, especially the Lo, Mid and High Tunes --- I'm sure once I get the AF gauge working properly and the car idling properly I'll have to redo all those numbers again.
Not using the timing functions yet. Which VE table am I using? that's a good question! ;) As you can see I'm still learning how to use this as well.
born2drv
1,199
Burbank, CA
ok well the ground isn't the problem, is there another reason why i could be getting the oscillating WB reading??
i'm going to clean out my ISC and install a new check valve, etc and hopefully that will fix the idle problem.
chriso
Supranian
Bay Area, CA
My idle problem appears to be fixed for now. I took turbobobs advice and made sure that the PT Tracking was turned off. You can do this by verifying that the Cruise TPS and Idle TPS settings are at 4.90. The reason for the idle surging is that the PT Tracking and the ECU are in constant battle over the AFR and that in turn causes the idle to oscillate. At least on mine it did anyway. Check your PT settings Yosef.
Oh, and btw, you are running VE Table #1, I checked your settings against the VE Sheets.
born2drv
1,199
Burbank, CA
thanks chriso, i changed the cruise/idle TPS to 4.90 and the FE tracking to 30, it helped to make things smoother but I still have a high idle and the oscillating WB readings.
the shop i had it tuned at first said it was idling fine then they hooked up the maftpro or something and it idles very high and rich, they want me to bring it by and let them play with it some more, we're going to look at a few other things to and try and track these issues down.
if someone has an idea of where we should start looking i would appreciate it. thanks.
chriso
Supranian
Bay Area, CA
I believe the FE Smoothing doesn't really apply to our cars (I could have teh terminology wrong), I think it should be set at "00". See my MAFT Pro thread for the comments from Turbobob to confirm.
turbobob
196
Near Detroit
The MAFT Pro calculates "Flow Error" when you have a MAF and MAP both connected. You can see it on the LCD and log it. The FE smoothing simply makes the graph more readable. It has absolutely no effect on the tune.
B
born2drv
1,199
Burbank, CA
so if that's the case then what else could cause my wideband reading to oscillate like this?
what else could cause a higher then stock idle? anything? my car idles very rich at around 1200-1300rpm?
i'm not blaming the maftpro, maybe we hooked it up wrong, i dunno, just looking for some advice to trouble shoot it. is there a way i can rule out the maftrpo without hooking up the maft again? (i don't have my maft anymore and my intake pipe is now too big and i don't have a reducer or a air filter that would fit)
thanks again.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Also, pull back the butterfly, make sure it closes all the way, mine was high and it was from the t/b, but I dunno if you ever messed with your at all. Did you do any mech work also, the pro should maybe change a/f , but not idle rpm. That sounds more like t/b, or vacuum leak of some sort.
