my hp and 1/4 mile
7mMk3Pimpin
11
DirtyJerzy
i wanted to know if some one can tell me my est. hp and 1/4 time my car is getting fixed over the winter to get ready for spring i have a 87 turbo 5 speed manual with guessing 50-60xxx miles on it the spedo broke before i got it from sitting from friend for 2 years and before that from failed marrage which wife won and fu**ed up body but never drove, the aftermarket i have is 3in dp, 3in test pipe, hks super drager , a hks super mega expensive green filter, 550 rc injectors, 255 walbro fp, fuel press. reg., 2.5 harde ic pipes and after market intercooler not sure of what size didnt buy yet, hks super squential bov, and aem ems (cause eventually i want over 700 to the wheels), and friend that i got it from said upgraded ct 26 im not sure though, and a cometic hg torked to 80 and lexus is 300 wheels with i think 225/45/17 on them. what do you think i can run with this car you guys decide how much boost i should run thanks any good educated educated guesses will be greatly appreciated. thanks.
MRSUPRA
838
Maryland
With an upgraded CT-26 and about 20psi of boost, high 12 second 1/4 mile times shouldn't be a problem. With drag radials and an aftermarket clutch, you could probably do low 12's.
His answer is no more vague than your question. You need to get your car together and have it dyno'd. That's the only way you'll find out what you want to know. You can also look at other supras on here and see who has similar upgrades and see what they're putting down at the wheels.
Try using punctuations and capital letters to make your threads easier to read. You may get some better answers. Alot of members on here won't bother reading it if it's going to take an act of congress to help them understand it. Good luck with your car.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I think Aaron's answer was pretty acurate. 200-400 HP depending on the tune and amount of boost you will be using. and 17-14 seconds depending on how good you at at launching and shifting without having an upgraded clutch or drag radials (or at least wider tires, I foresee lots of spinning with 225's ;)).
drjonez
the motor city
www.4cefed.com
bigaaron said:
Somewhere between 200 and 400 whp, and somewhere between a 17 second and 14 second 1/4 mile. :biglaugh:
exactly.
posts like this are retarded...GO FIND OUT!
drag racing is entirely dependent on the driver....you can have 920359043905094rwhp and still run a 15...
MKIIINA
Destroyer of Turbos
Plano, TX
well since you went the weight reduction route by deciding to not sure punctuation im sure youll run deep into the....shit iunno....10s. get rid of those pesky commas and it will be 9s....
on a serious note it depends alot on the driver. when my bro drives his car he runs 15s, when i got in the car and did nothing more than change the position of the seat i dropped a full second off his time on my first pass.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
You never know until you dyno and take it down the strip. Anyone can guess, you could have 720 cc's and vpc and still do 280hp and 15.1 because of a crappy tune or a weak component.
7mMk3Pimpin
11
DirtyJerzy
to the people that gave me a good guess thanks to the people that are jokester just don't waste my time and breath reading your crap cause you aren't helping I just wanted a ballpark average not something stupid like 5-10000000 hp cause you are not any help
