My damn PSP stopped reading discs :(
OneJoeZee
Retired Post Whore
aboard the Argama
MKIII N00b said:
Custom Firmware 3.51 M33 <<<thats the one im DLing.
note this
Downgrade 3.50 to 1.50
The 3.50 downgrader requires you to use a Lumines UMD.
(Note: The Korean version of Lumines is not supported by the downgrader at the moment.)
Just having the firmware upgrade file isn't sufficient. You have to downgrade to 1.50 first.
OneJoeZee
Retired Post Whore
aboard the Argama
oh. ok. Just make sure you have your power plugged in so your battery doesn't die during upgrade.
Just unzip your ISO file to the ISO parent folder. The game should come up under the memory stick column on your homescreen..
OneJoeZee
Retired Post Whore
aboard the Argama
Make sure you unrar'd all the right files in the folder. Alot of times, the games will come in a lot of different folders with other rar'd files. All you have to do is unrar one of them and Winrar will automatically put the whole thing together into one file for you. If you did it right, you should come up with one full large ISO file.
BTW, if you can't find Street Stage on your PSP, you can borrow mine or something. I have it on UMD. But this will be good for you to figure out since you can do practically everything on the PSP off your memory stick. It helps to have a bigger stick though... Or multiple ones.
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
Whats the fastest you can get your initial D over here? ;)
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Search for SNES TYL and SNES ROMs. Make sure you have the correct firmware version and are able to run/emulate. Then you can play all the great old Super Nintendo games you want.
OneJoeZee
Retired Post Whore
aboard the Argama
MKIII N00b said:
dammmit...there isnt anything fun to do on my PSP. are there any games that i can put on the stupid 1gig stick that i can play?
Dude, everything you want is a short search away on the pspiso site. It will tell you how to add emulators, homebrew games, eboots, all of that stuff. There's tons of games to download there. Go poke around there a bit. You'll find what you're looking for.
