bigaaron said:I guess you received the engine and trans :biglaugh:
Nope, no trans!:icon_razz
Sure did, and the only thing damaged was an I/C line (which I don't need, so no sweat off my nuts). Thanks Aaron!
rakkasan said:I pulled everything off to put it on, and it's a pain in the ass. I'm bead blasting the charge pipes today to make them look new again, so I should have them back on tonight
I'm glad I decided to before I put the motor in, because I can't see how it can be done after the swap is completed....
So you're the one that bought it! What's it like, how is it?
Justin727 said:could have gotten a 2jz
Justin727 said:come on over to mississippi and rub me right
rakkasan said:Cool Scott, 10psi isn't even starting to turn the compressor much. Tickle it to 23psi & it should open up quite a bit....
I can't wait to see what your numbers will be, so hurry up! :biglaugh:
