my 88 turbo targa 5spd buildup for drift
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
stan said:
-my compressor wheel is chipped
-i'm leaking exhaust like mad off the back end of the manifold
-the car overheats badly when idling
-i have rod knock
-i dont get 6psi boost unless im going at least 80mph
the solution? i'm going 1j. end of story.
LOL
supra90turbo
shaeff is FTMFW!
MA, 01440
stan said:
-my compressor wheel is chipped rebuild/replace/upgrade
-i'm leaking exhaust like mad off the back end of the manifold probably a stripped stud hole. helicoil and replace stud
-the car overheats badly when idling replace the headgasket
-i have rod knock rebuild the engine
-i dont get 6psi boost unless im going at least 80mph well, you're not going to make much boost when you have a massive pre-turbo exhaust leak, because it's acting as a wastegate, and you definitely shouldn't be trying to boost when you're overheating and have rodknock either....
the solution? i'm going 1j. end of story. oh absolutely. 1JZ: the cure to everyone's problems.
argh.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Accually when you think about it, He is making the right decision with the 1jz.
Call me biased but hear me out.
Whats the title of this thread called?
It says drift.
The 1jz inherentally has amazing response and has a better oiling system than a Stock 7M-GTE does. When the oil is sloshing around or being held at odd angles for prolonged periods of time, it makes sense to get somthing with a god oiling system.
Anywho, he also calculated to have Driftmotion build him a really nice 7M. They quoted him the same to have one of their awesome swaps done.
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
It says drift.
But while all this is true and correct, the 7M is a torque monster which is what you need for drifting...and you said Driftmotion could build up a nice 7M for the same price as swapping in a stock 1JZ... Just my .02 and not meant to start an argument or anything...
stan
its not that it would be hard to fix those problems, its that they are pretty likely to just come back again.
kyle - no. there are no decent hachis for a decent price, so i'm looking at other stuff (for everyone else, i was talking about some sort of beater / backup / parts hauler for while the mk3 isnt running)
stan
!!!!!!!!! got the 1j today. engine is now sitting in my garage. wooooo!
stan
WTF!?!?? i was moving my wheels justnow, AND THEY HAVE CRACKS. ugghhh BBS mesh wheels i got from rbmotoring and at least two fo them (havent checked the others) have little cracks on the inner lip ugggghhhhhhhhhhh. can this even be fixed?
