more cooling needed.
1-2clutch-u
379
chi town and ohio
hey all I'm at the track right now (road racing) brakes are fine n all but I need more cooling. like my coolant temps are high. starts at like 205 ish but if I chase people down the I got up to almost 230 at 1 point. I have the bigger rad with e fans that supposedly flows over 2000cfm. I got a 160 deg t stat. even got the rad block off plate. coolant is about 50/50. unsure what else I can do. and no driving ez is not an option. gotta woop the stangs that are here.
jake8790
Life's too short for N/A
Dec 18, 2011
395
Oregon
Ditch the E fans, go to the stock 10 blade clutch setup with shroud. Do you have the undertray on the car?
5
Undertray is important at high speeds (i.e. road racing) There's a lot of plastic pieces on the front that funnel air to the radiator...if they're missing guess where the air isn't going.
High speeds, the fan isn't doing anything anyway. At lower speeds is where you need the fan, but what setup ydo you really have? Need pics.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
Undertray and stock fan is the way to go, as mentioned.
160 tstat wont help at all. Also, make sure that your rear hood seal is intact.
91Supra313
1,062
Clarksville TN
I don't know how much this would help, but if the temps are that high, run with the hood off. Not sure if that is legal for your races, but that means a hell of a lot more air cooling off the motor. Plus there would be zero hot air trapped.
1-2clutch-u
379
chi town and ohio
no bhg. at least i hope not again. but after 20 years the clutch fan is still the best thing we got? Got a 3 row alum rad with 12 in fans. Also I have a carbon fiber hood so it has a reverse scoop in it. And I dont think I have a rear hood seal bec the hood.
planemos
559
Slocan Park, BC, Canada
Do you have to run 50/50? Just water and maybe some water wetter would be good. Especially since it is now almost summer. Do you still have the AC and evaporator in there? You could try ducting as well. Make some ducts to direct air to flow through the rad. Possibly cut holes in the front bumper.
5
Short term, not good for the water pump bearings. Long term, have fun with corrosion... Coolant in the cooling system is used for more than just antifreeze.
mkiiichip
1,434
WI
If there is coolant getting to the bearings of a water pump, it is dying. It doesent matter if its water or coolant. I agree with the corrosion bit.
8,900
Coolant doesn't boil at 212, so the whole idea of straight or mostly water in Florida or other places is from the bad idea fairy.
8,900
1-2clutch-u;1927035 said:
rather not go with the stock fan. really hate that fuker. no undertray eather. can it drop 30 deg off my temp?
For what reason do you hate it? Because it slips and doesn't draw engine power when moving? Or because it moves more air when it is standing still? So you take things off the car Toyota put on so it will cool, then you ask if putting them back on will cool it? Priceless. I love the interwebz....
5
It's bad for the bearings because no lubrication for hte seals = water in bearings. Only reason to run pure water is because a track requires it.
MNBmk3T
217
Burnaby, BC
The stock clutch fan is by far THE best way to cool your radiator. The only reason new cars have E-Fans all the time is because they are all wrong wheel drive and the engine is mounted in such a way that a mechanical fan will not work. Unless you want to spend some serious money on quality electric fans like some SPALs (the ones that a couple of my friends use are around $250 PER FAN, let alone the SPAL specific relays you need). I am E-Fan right now with my 1JZ and I do have cooling problems. I'm going back to a stock clutch fan with the shroud (with the auxiliary fans wired into my EMS so that they come on when the water temp gets too high).
The amount of air that the stock clutch fan flows is untouched by virtually ALL aftermarket (except SPAL ones from my knowledge). There's a reason why guys like Ryan Woon and Cody Phillips ran the stock clutch fan in their cars when they were producing upwards of 1400+WHP back in the day.
Spal fans make fans for oem cars. And the best ones flow a lot of air. Only real good option besides stock.
