MOES's Bigger is better > SWAP
OneJoeZee
Retired Post Whore
aboard the Argama
Moe, what supporting mods will you be using with your K26 twins? Once your car is running and my car is running(more than 10psi), I'd like to compare and contrast with your 3L setup.
OneJoeZee
Retired Post Whore
aboard the Argama
suprastanger507mgte said:
Well...........getting pretty close here:
Got most of my stuff on Saturday to finish the project:
One Piece Steel Driveshaft from JawsGear - Man what a difference in weight this is compared to the stocker.
Wiring Harness and ECU - :)
Thanks Jeff @ Jawsgear
Harness - extended and ready for the car. Just need to splice in some power wires into fuse box etc.
XS Power Single turbo Manifold -
Lower Radiator Hose
Steel braided line to bypass Fuel dampner .
Thanks Ti @ Jawsgear
ISC Valve,
Throttle Cable bracket
Thanks Eric @ Jawsgear.....
I just need to order the fuel rail spacer from Toyota
Pick up T/4 / to T/3 adapter from ATP - They are 3 minutes away :)
Order the downpipe from Drewgo
My Camera battery died so no pictures. :(
Wait...
What?
You're not gonna use the K26 setup anymore?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
I am going a complete Emanage blue setup / timing, fuel, injectors..etc...
550's MKIV , Walbro, and may use this same setup with the K26.
jawsgear
Undergoing Construction
Jan 29, 2006
465
Sactown
www.jawsgear.com
lol... NICE~~~~ !!!! Sam told me about the little hiccup and some wrenches flying around in the shop.. lol :biglaugh:
Nah, wasn't a wrench. It was a broken polished valve cover flying across the parking lot at about 8pm LOL. :icon_evil If you know any one that has an extra valve cover LMK. I need the intake side with the oil filler.
Jeff
suprastanger507mgte
Hayward , Ca
Jeff
Mike G has a set Jeff. Contact him.......what a bummer though lol.
suprastanger507mgte
Hayward , Ca
Picked up >
JIC Magic Lower Bar
Kaminari Side Skrits
Clutch line
Thanks Chris for picking these up > ( S!kes)
Impulse Buy :
JDM Tail lights , the darker one :)
And a set of free Saw Blades for the Cressi > Thanks, Chris O
