Modifying a California spec Supra
AaronB
Georgia
Ok guys, hoping you guys can help me out on this. So I have an 89 Turbo that was originally from Cali. It's 100% stock, and unless something happened in the past 25 years I assume it still has the Cali parts for "emissions". I want to put in a new downpipe and catback, and I'm wondering if the California specs will throw off the ECU and throw a check engine light. There's not a lot of info so here's what I know:
The main difference is the Cali cars have a pre cat like regular turbos, but additionally have a 2nd o2 sensor, an additional probe to the EGR system, and a different ECU(i found they have a separate part number). So I assume the 2nd o2 sensor is somewhere on the downpipe, near the pre cat. Now since a new downpipe will eliminate the pre cat (and presumably the 2nd o2 sensor) then I would assume the car would throw a code 27 and the code for the missing pre cat (forgot the number).
Now if that's the case can I just replace the ECU with a non cali 89 Turbo one? That would offset the missing pre cat and 2nd o2 sensor. It would still leave the additional EGR probe, which I assume can be removed while leaving the EGR in place (to keep EGT's down).
The point of this is the figure out how to modify while getting around/removing the extra restrictions surrounding Cali cars. I also hope this can be an end all reference as I found very little info of modding a car with these restrictions. Any info would be greatly appreciated! :D
Oct 11, 2005
3,822
27
Thousand Oaks, CA
The secondary Ox sensor goes in a bung on the downpipe (non-turbo only). Everything else is the same as on federal cars. Your best bet is to swap in a non Calif ECU. Uses the same ECU connectors and is plug and play.
AaronB
Georgia
Thank you for the confirmations 3p14...so to confirm, by installing an aftermarket downpipe and catback, swapping to a non cali ECU, and removing the EGR probe, i would essentionally have a regular Supra with an aftermarket downpipe and catback. Glad to know the additions aren't hidden deep within the car's electrical system.
