MKIV NA Rims: Tire Question
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
i got the MKIV NA rims and im lookin to replace the rubbers on the rears sometime in the future. they are 16x9. what is the widest tire i can go for? i've seen 255s on sawblades, so i know i can go bigger..
whatchya think?
thanks
bgrieger
Toronto
You could possibly go wider than 255 depending on whether the tire maker says a 9 inch is an acceptible rim width, if of course you could find wider. DR's shouldn't be too hard to find larger, but street tires will be a bear to come up with.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I have 245/50's. It is hard to find tires wider then 255 but 255 has a 50 side wall which would be kinda tall.
dbsupra90
toonar
indiucky
255 is about as wide as you can find for 16" rims. and even those are sometimes hard to find.
they will fit just fine on a 9" rim btw.
