Got my new rear brakes in (finally), here's a link to the pics!
mysupragallery.com -> rear brakes
did these during down/rest times while working on replacing HG. pretty easy, drill the bolt holes, shim the rotors, viola, it's done.
At this point is when you notice that the MK4 brake line is too short
. I used a LS430 front caliper hose on the driver's side, still need one on the pass. side (the mk4 line is pulled pretty tight, but will work for now).
Got all the stuff for the front brakes, except for the LS430 caliper bolts (m14 x 1.5 x ~ 100mm is difficult to find at places other than Toyota....), and still have to machine out the mounting bracket.
