Mk3 oil filter relocation...to where???
GilTheArtist
34
California
Im about to order the summit kit, and was deciding between mounting just under the crossmember near the drain plug, or all the way across the oil pan to where the AC bracket used to bolt into the block.
Who's actually done this and where did you mount yours?
Yes i have searched btw but i cant find anyones build thread thats actually complete with pictures and details, lets start one because the stock filter location on our mk3s is a nightmare.
8,897
In the cavity on the hold down mount for the truck transport.
Also, I started with this and changed my mind.
Then I put on the Canton relocation adapter. You should too.
GilTheArtist
34
California
Man, @nickm you got rid of the oil cooler? Hows that goin?
Anyway, first lesson is dont order anything Summit brand. It literally all ended up being defective.
I ordered the driftmotion pieces with welded in/outlets. I also*got some 5/8 stainless steel hose,*a pair of 90 degree AN10 swivel hose ends, and a pair of straight hose ends off Ebay.
After properly removing all the AC stuff from the engine bay, i ended up mounting the filter right in front of the radiator where the condensor once was.
This is also gonna let more air hit the radiator and might cool the filter too. Ive also got plenty of room left for a future auxiliary electric fan.
I also installed a Fumoto drain valve to replace the stock drain plug.*
