Hey guys getting really close on finishing up a swap I am working on. It is Aristo 2JZ-GTE w/ A340 into 88' MA70. I have everything wired up as per the million posts and diagrams. One thing I am not sure about is the Speedo Cable and then the buffered signal that is sent from the Dash to the ECU. If the factory cable does not mount up and power the dash then is the signal from the dash useless? What have others done to get a speed signal to the ECU? We have a Rev/Speed Meter for display but need to make sure I have the right speed for the ECU(or does this just come from the A340 and is pre-wired?) and is there a way to use the stock cable?
So basically has anyone figured out how to use the factory MA70 speedo cable to power the dash speed gauge with the Aristo A340?
Thanks
Seth
Thanks
Seth
