MBC
SDtoyomk3
46
san diego
i installed a manuel boost control about a week ago made from a Home Depot brass adj. valve piece....i was wondering if i need to do nething enginewise along with adding the mbc...im only using it to boost 9 or 10. so not too much but i was just wondering if theres nething else i need to do?
C
cnewingham
Guest
if you are going to stay in that range then you are fine. I use to run 13psi on a stock hg but it was on a new hg and healthy eng.
where in san diego are you at?
SDtoyomk3
46
san diego
i replaced the head gasket with a Greddy metal head gasket(forget wat size) so itll outlast the rest of the car. im in el cajon area. u?
