Master Cylinder Brace
steveyblack
529
Nj
how dose it exactly attach to the master cylinder? through the mounting brackets on the fire wall??
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
No it bolts to the strut tower and has an adjustible bolt or like foot that you can slightley preload the master cylinder to stop the movment under hard braking.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Ok well here are the pics but rember its a prototype so if any thing needs changed or adjusted nows the time so i need your guys input. The bolts should be in tomorrow so when they come in ill post some better pics
wesbeech
Feb 26, 2006
1,022
Akron Ohio
buckshotglass;878689 said:
Looking good man. I didn't know it was an issue, but that's a nice simple fix.
Yes it is on some cars more than others when i get a chance ill post a video of the flex without my brace and then with my brace so you can see the differance.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
CryoSlash;878695 said:
i'll buy one... but the bolts for the suspension worry me a bit...
What worrys you with the bolts?
CSNOW i think the cheapest i could do if we got enough tpeople is $60.00 shiped with everything needed and a lifetime warranty if you some how break it send it back and ill fix it for free. But only if we can get enough people toghter.
csnow
Matthew 6:33
Palm Bay, FL
Mark me as your first customer.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
chrisfromda909;878783 said:
I assume a strut bar is out of the question using this.
No i will make it so you can still run a strut bar. Im gonna go do some R&D on that right now.
