Masive inline 6 twin turbo engine found at local scrap yard
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
Thought id share, a friend of mine dropped a load of scrap metal off and saw this beast, its actually sitting on the block, the scrap yard pulled the oil pan off to get the rotating assembly out. Twin turbos, each facing the opposing direction, the inlets were a good 6-8 inches!! :aigo:
Chambers
Now you know
Sep 9, 2007
983
toyotanos;1700366 said:
So what, you goona bolt one of those turbos to the 1UZ ;)
Haha, I thought about one of them for a compound set up for my truck, but I dont think a 4.0 would ever spool that alone. The engine would idle and the turbine wouldnt turn, haha. :)
te72
Classifieds Moderator
6,625
9
WHYoming
Generally engines that big are marine or used in compressor stations. We have engines up here in the natural gas fields that you could park a small car inside the cylinder bore...
te72
6,625
9
WHYoming
I'd be more scared to think of how fast those pistons have to travel to spool them...
jstricker
68
Kansas
The pistons on the existing engine? Not very, it will only spin about 1500 rpm max at rated hp.
I'm with one of the earlier posters, Waukesha, maybe an older Allis and most likely a compressor or genset power plant. It could really be any kind of stationary power unit though. Pumps, oil field drilling/pulling units, etc., etc. Had you looked a little closer there would have been a data plate on it somewhere that would have told you all kinds of useful information.
John Stricker
Russell, KS
(Been working on ag tractors and industrial engines/equipment most of my life)
toyotanos
What will we break today?
2,844
Coon Rapids, MN
PM member Chambers and see if he's stopping by again- might be interesting to "discover" the engine's story :)
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
engines like this usually spin at a constant speed. the turbos react more to the engines load than they do to the speed of the engine. as i have said before its too small to be a train, and way to big to be mobile. its probably a generator,pump, or powerpac setup from a drilling rig. but if i had to guess id say generator
te72
6,625
9
WHYoming
Good point. I don't have much experience with this sort of engine, just know they're all over in the fields around here.
