The timing was off. Way off - Advanced -
Make sure your CPS bolt is tight!
I could only hear it occasionally, at idle. Never while under load while accelerating. When it did happen I tried to determine if it was just the injectors, valves, loose heat shield... Never could quite pin it down, cause it wasn't consistent. I am not for certain the length of time this occurred. It was at least a couple weeks if not more. Pretty sure it was not more than two months.
So I did some research on possible causes, besides those I listed previously, and came up with water pump going out, harmonic balancer loose and timing off. The easiest and first thing I checked this evening was the timing and it was way off. ~17° base. I corrected it and no more rattle.
This thread is to find out what kind of problems I should expect and how to test for them. :icon_ques
