MAP ECU mounting suggestions
SupraMan1987
258
Hickory area, NC
Hey guys, just got my new to me MAP ECU, and am looking at where I'm going to mount it. I know I'm not the only person here that has one, so where are you guys mounting yours? Velcro to the bottom of the factory ECU? Any ideas or suggestions would be appreciated, I think it will be getting installed sometime in the next 2 weeks.
Huge amount of room above the glovebox..
leftynridge
401
dayton, ohio
I had mine mounted to the panel right below the glove box. You can't even see it and plus you will want easy access to plug in and out your serial cable to the map-ecu for tuning purposes.
