map ecu 2 two-step video
stevenr816
932
Phoenix,AZ
the reason why i ask is because the msd dis 4 sounds like crap, and doesnt even sound like it builds boost even on an srt4 (streetfire videos) so i want to see if map ecu 2 has a true two step/anti lag system
steven
stevenr816
932
Phoenix,AZ
drjonez;920384 said:
who cares what it sounds like? does it function? yes. the DIS 4 DOES build boost....
i was just curious thats all, so the dis 4 does build boost? cause the video i saw sounds like it builds 0 boost at all only because it is very short
here: i just looked and it is dis 2 if that makes a difference
http://videos.streetfire.net/video/e1999fd9-927d-4174-8f35-c0b55a9ffa70.htm
i wanted something like the wotm supras have :naughty:
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
it depends on how you setup the anti-lag or 2-step.
you MUST retard the timing for when the anti-lag engages. when i setup my friends AEM, i retarded the timing with 2-step engaged all the way down to 10*BTDC. i set the ignition cut at 4500 and the fuel cut at 4800rpm. with it set up like this, he can build anywhere from 10psi to 14psi on a ITS72mm w/ 0.86ar hotside depending on throttle angle. the exhaust note changes DRAMATICALLY when the ignition timing is properly altered for 2-step engagement.
