MAP ECU 2 Is it right for my setup goals???
pln
Get the gate!
Apr 10, 2007
107
eskilstuna.SWEDEN
IJ.;1399297 said:
IC is doing a good job then, do you log the Hotside IC temps?
(mine was 77c out of the turbo and 25c out of the IC @ 1bar)
no i have never logged the hotside.. would be interesting.
what ambient temp did you have then.
pln
Get the gate!
Apr 10, 2007
107
eskilstuna.SWEDEN
IJ.;1399305 said:
20c that day.
It made 362rwhp @1 bar
ok thanks for the tips IJ. I will look in to the spark issue. Wich sparkplugs do you recommend?
I have tried to build with good cooling in mind. 99% of the air the fans sucks in goes through the ic. Have you tried to waterspray ic?
I was running NGK Coppers heat range 7 gapped at 22 thou.
No I try to run my car as I do in the real world and spraying the IC isn't really practical (or needed being a 4" core)
There are limits to what you can achieve using a piggyback as you don't really have full control and who knows what else is going on in the background?
pln
Get the gate!
Apr 10, 2007
107
eskilstuna.SWEDEN
"There are limits to what you can achieve using a piggyback as you don't really have full control and who knows what else is going on in the background? "
exactly. That has been bugging me all along on some matters.. i suspect. Cant wait to go stand alone now.
Never been a big fan of PiggyBack's once I learned how they do their thing ;)
Pretty well went standalone from the start and have worked my way through 3>4 different ones as I needed more advanced features
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
Harford County, Maryland
I'll second this, thats why I was asking about the ambient temp. Seemd like it was pretty nice IAT's.
:( well I already bought this one and im going to try and get the most out of it. I have seen 500+ hp with less than this, so its not out of the question. Will it be flawless and able to kill your monster....? Hell no, but it'll be enough for me to have fun in :)
