Making a test pipe sorta
Toyotaxtreamteam
231
Mass
i am using a piece of pipe to connect the pipe before and after cat together what size pipe would slide over or into the pipes thanks , any one do this?
Toyotaxtreamteam
231
Mass
ok stuck again the freaking cat is off and all cut both flanges off and now i find out the pipe before cat bends toradw up a bit, f&*& now what i dont have a pipe bender and all the sections and the auto parts store i dont think are gona help should i use a flex pipe until i can get a place to bend me a pipe ?????
supra90turbo
shaeff is FTMFW!
32
MA, 01440
lol always plan ahead.
never cut both flanges off. You can use a flex pipe as long as you promise to get that done the right way, like tomorrow. then it's ok. otherwise, you're a hack. lol
mkiiSupraMan18
Needs a new username...
United States
Hacks rool
Just run open DP! That's what I'd do. Then worry about your exhaust later, or never, whatever.
*edit*
Oh, this is NA, lol
Flex pipe would still work fine, IMO. No1 will see under there anyway. *So no1 will know if you don't tell them* :icon_bigg
Toyotaxtreamteam
231
Mass
well got it all together checked and tightened the clamps all leakes are gone but the exhaust sounds great kinda on louder side but real deep, i am thinking of geting a silencer to drop into the muffler for now until i get a hi flow cat if i ever do depending how it feels once i go for a ride in a bit, btw is there a way to make a silencer i heard there was??? well gona go for a ride
Toyotaxtreamteam
231
Mass
ok heres the result the car picks up better and seems like it has a bit more guts and much louder which i like, heres the con for some reason the exhaust that was put on the car when i bought it is some cheap 3Aracing makes it sound raspy, i am gona start looking for a decent muffler to get a better tone
