maftpro is working
malloynx
NC
well bob,,, i just reinstalled 4.20 and the car is actually pulling on the highway.. not breaking-up or sputtering.
also i did what you told me to do with the boost solenoid and same thing is happening
turbobob
196
Near Detroit
answered your PM on full throttle
how is the solenoid hooked up. A solenoid that is plumbed backwards reactls a lot like what you described.
B
guards_man79
74
Georgetown, KY
ok, i'm lovin everything i've read about the maft pro and i'm bout to buy one. i'm wondering with all the things that the maft pro does. at what point would i need a lil extra fuel control (i.e. apexi neo/ emanage and so on).
turbobob
196
Near Detroit
There have been tunerpro issues, that have been solved 98% I think. Mike Malloys issues relate to the wiring, not the pro.
Version 4.63, 4.65, 4.67 are all posted, and run fine, the response stuff is a lot better in the new stuff, and there is a second VE table in there (selectable from the settings page) for cars with stock (high idle vacuum) cams (like my Stealth).
The revision to Tunerpro is almost done. We are working on the log review/replay functions right now.
B
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
i was wondering if someone can chime in on this for me. i have the car running with the maftpro i have some idle studder and my air fuel ratio sweeps from 14ish to 16ish but it does hold at 14ish for several secs then leans out a bit then goes back to the 14 range. anyways i checked my monitor page on the maftpro and the o2 signal reads 2.4v - 2.6v but i checked the aux 1 signal and it reads 0.01 range when the car idling. i read someplace on supramania (if i remember correctly) that the aux 1 signal should be reading the vf signal so if thats true my vf signal is not where it should be. i have the purple wire tapped in the vf signal wire on the engine harness. im running version 4.63 if that helps. i searched aux 1 on this thread and nothing came up.
drjonez
the motor city
www.4cefed.com
"sweeping" @ idle is normal as idle is closed loop....albeit slower than cruise.
as always, mkiiitech.com has your answer:
MAFT pro wiring:
http://www.mkiiitech.com/forums/viewtopic.php?t=641&start=15
Vf logging info on p.3:
Vf logging:
-set Aux1 mode to 0
-connect purple wire to Vf
Vf info:
http://www.mkiiitech.com/forums/viewtopic.php?t=593
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
thanks for the quick reply.. i just wanted to know if i should be getting a reading other than 0.01 on the aux 1 signal on the maftpro cause im getting 2.4v (or so) on the o2 signal on the maftpro.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
I have read quite a bit on setting up the boost with the Maft Pro but I am not getting the right results... I'm sure that I don't have the right config.
Can someone tell me what the settings should be??
I want to run 14psi on stock turbo.. What should my settings be?
PSI start, DC etc... I am using 4.63..
mhopemk3
Jul 13, 2005
762
I did. I changed a few things like he mentioned and got it increased but still have it die out. I think the DC is the cause..
I wanted to compare what someone has already accomplished (a different way) to what he wrote in that post..
Thanks,
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I record data on tuner pro, but cant play it back! It says i have mismatched ads and xdf file. I have tpro4600.bin, and tpro4600.xdf on tuner pro page, It says ... \Program Files\TunerPro RT\522.ads for definition file on aldl setup page, what do i need here and how do I get it?? And any updates on a date for new tunerpro??
harry89supra
Vancouver island BC
this sounds like an incredible product... i want one bad!!! i think i would be easyer to undertsnd once i actualy have one. is there a certin modle that ppl are haveing problems with? ill be ordering one shortly Doc.
C.44
164
Behind the keyboard...
FINALLY, i've read all 18 pages (yes a mere 18 here ;)) and i still have a car specific question. I'm in the proces of getting my 88T up and running. Other then my RC550's, SP61GT@9psi and a 3 - 3.5" DP (approx ;)) my car/engine is stock (yes a stock non metal HG too). I have a Lexus AFM but it's not installed yet. Engine isn't even running yet.
Now i've been told before to get a Walbro, FPR of some kind and SAFC. Now i just hate the flashy looks of the HKS stuff since i think it doesn't mix with the supra's interior.
Anyway, my question. I will purchase a Walbro pump and a MAF-T Pro with boostcontrol and Wideband going for a speed density setup. But do i still have to get a FPR or would that be redundant ? I'm sure i will be upping the boostpressure to about 15 or so but not anytime soon (need to break it in first).
Any insight ? Need to get my shopping list complete ;)
