maftpro is working
NJsupraA70
Ex-Supra Owner
Sep 18, 2005
276
NJ
here are good pics for anyone wondering which resistor to clip.
polobai
Orlampa
doc, great job shipping my maftpro so quick, but i believe i dont have the most recent update with it. does mine come with provisions for the zt2 and timing monitor, or do i have to download something for it? if i do, do you have a writeup on how to download while the unit is out of the car?
drjonez
the motor city
www.4cefed.com
complete update instructions are in the newly released instructions:
http://www.fullthrottletech.com/showthread.php?t=1644
drjonez
the motor city
www.4cefed.com
jtamulis said:
Heya DrJonez, I wonder if the MAFT-Pro can do what would norally be the VF
meter too, that would be a pretty cool feature, to see how the car is running
acording to the computer.
Jeff
sure can. instructions from mkiiitech.com....
Vf logging:
-set Aux1 mode to 0
-connect purple wire to Vf
drjonez
the motor city
www.4cefed.com
just a note to those using the timing monitor- after setting it up, you'll need connect a timing light @ idle and adjust Tm Base to match up the MAFT pro's timing reading and the reading on your timing light. it may be a good idea to take some readings at higher RPM as well and use Tm Correct to correct any differences seen in the high RPM.
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
Why do we need clipping that resistor for again? I can't find any relevant posts before yours and the one that came with no pics in but still I don't understand what this tip is for :confused: :dunno:
polobai
Orlampa
doc, from that link i still cant decipher how to download the new version of the software. Am i missing something here, or what? Please assist for the goofballs like me on the forums.
dbsupra90
toonar
indiucky
it is the afm input pull-up resistor. you dont need it anymore to monitor timing.
drjonez
the motor city
www.4cefed.com
http://www.fullthrottletech.com/showthread.php?t=1547
yup.
note that you must be running speed/density to monitor timing (you're using the AFM input to monitor timing...).
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
Ok let me get this straight cause although I've been checking this thread very often and carefully this seems to be an issue that just jumped out of nowhere. So, in order to use timimg monitoring on the maft pro we need to clip a resistor? I thought that was a mere software matter...
polobai
Orlampa
thanks for the link doc, do you know if the Maftpro you sent me already has the latest update(version 4.4), or should i download the latest version to be safe?
drjonez
the motor city
www.4cefed.com
how is this an issue? it has not jumped out of no where. clipping the resistor is NOT difficult....
yes, in order to use the timing monitor you will need to clip the resistor.
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
Well I guess "issue" is a heavy term and might have sounded more serious that intended. What I'm saying is that the resistor clipping was not mentioned untill now thus it came out of nowhere. And while we had been talking about the timing monitor function no one mentioned that the maft pro transistor was to be modified in order to work that's why I was under the impression that it was just a case of software update. No big deal. All I said was that it wasn't discussed up until now and the resistor clipping detail was not mentioned before...thus...surprise :icon_conf
isnms
United States of America
Oklahoma
i80.photobucket.com
drjonez said:
yup.
Ahh, that's the part I missed.
I thought I had read all the directions, but I missed that. Thanks.
