maftpro and HAC signal
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
Is it ok not to use the maftpro harness wire dedicated to tapping into the hac signal and just keep the stock hac sensor in place? Im just wondering?
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
Ok kool. Thanks for the quick reply. Just to safe there won't be any reduced performance from the maftpro if one keeps the stock setup?
chriso
Supranian
Bay Area, CA
What about on 89+ cars where the HAC is built into the ECU? Is there a link to a description on how to do the mod?
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
Yes there is a write up on how to do the 89+ hac wiring with the maftpro. Im not sure where the post is but im sure a quick search will net some results. Good luck..
chriso
Supranian
Bay Area, CA
Search is bringing up no results for any write up.
CPT Furious
Now MAJ FURY!
KDOV
I think I might be a fool, but I pulled out my ECU and there are no wires attached. Where are the wires for the HAC? I realize mine must be internal, but how do I attach the MAFT Pro to it?
drjonez
the motor city
www.4cefed.com
'89+ ECUs must be hand modified if you want to break out the HAC signal. at some point i'll put together a nice writeup, but it's definitely not for the faint of heart/electronically declined.
