MAFT users... CEL from HAC?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I've been running MAFT for a few months now, I really like it but every now and then my car will run funny and studder, throwing the CEL. Clearly I know its my HAC because i get codes 31 and 32 (usually, if not always these codes appear together.) I have the MAFT correctly wired to the HAC harness.. its the red wire (http://www.supramania.com/forums/showthread.php?t=1469&goto=nextnewest). Is there any explaination to this problem? As far as I understand, the MAFT constatly spits a voltage of 2.8v towards the ECU. What problems can this cause, or what is causing the problem? Thanks a lot guys!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I'm not getting the same issue on mine - but I'lm running the 89+ ECU, and I don't have the MAFT HAC signal wire hooked up.
Perhaps try pulling the MAFT signal back out of the HAC loop, and see if your codes go away?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thanks for the reply Grim,
I was thinking about doing that, I guess it cant hurt to try.
Any others have issues with it? Anyone else running a pre-89 on maft?.. feel free to chime in.
