MAFT Pro upgrade from 4.89 to 5.03..... problems.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Hey,
I've posted this over at FullThrottle too, but figured it wouldn't hurt to see if anyone here had this issue.
CRE said:
I'm having an issue here. If I reflash to 4.89g , my prior version, the car runs great. If I flash to 5.03 or the beta of 5 that I've got my idle goes rich as hell (AFRs in the 10's), idle speed jumps by 750RPM, and I go lean when as I lean in on the throttle.
Thing is, PTT is disabled, stock ECU's supposed to be aiming for 14.7 and trying to adjust my tune makes NO difference that I can see.
Any ideas? I've compared settings between the flashes and tried entering everything fresh. What else changed?
The only thing I can think of is that something was erroneously changed in the Toyota VAF output scaling when version 5 was built.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
I had lots of problems when I was first setting up my MAFTPRO, i just flashed to 4.80 and it started working better. You might as well just flash back to the previous version til the new versions bugs get worked out.
CRE
Oct 24, 2005
3,485
Denver, CO
Yeah, I already flashed back... plenty of people running this version without problems though. I'll wait and see if anyone else had issues with it. Otherwise, I guess I'm waiting on Bob.
