Maft pro tuning question
89turbotoy
2 89 supras 2jzgte/single
Jul 30, 2006
309
cincinnati
wel if i set it all back to 0 it goes lean 16-1 so what do i do?
Down, what is ur setup if it is similar to mine maybe we can figure this out
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
I have a walbro GSS341 with a perminent 12v feed
stock 440's fuel pressure is 25psi with vac
stock ct26 at 13psi
main scale is -2%
low loads are all about -3% to keep vf@2v
mid load I have at +10% to max out the ecu adjustment so it will drop to 13:1 as soon as I make boost
high load -2% to -3% up to about 4800rpm
AFR is around 11.4 - 11.8 on WOT
My only thought is your fuel pump isn't up to scratch or your regulator isn't upping the pressure as you come on boost.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Why even run the HAC to the MAFT Pro? Feed it a set voltage signal from +B or VC (NOT WITHOUT THE PROPER SUPPORTING COMPONENTS! of course)... no worries about the MAFT Pro starting up too slow then. ;)
Does this error not cause any operational differences? As long as timing's not pulled it really doesn't matter, but I'd like to know. Especially since there's a way to take care of it without any codes.
http://www.fadingworld.com/Supra/Electrical/MAFT Pro/MAFTwriteup/7M-XXX/MAFT Pro and Codes.html
Same for dealing with the THA error code.
