(EDIT: new wiring diagram showing exactly what to do is posted on post #9)
Before I start off, I have searched and read through all the maft-pro archived threads that I can (a lot of the thread link listings are dead and don't work) and I am still seeing conflicts in wiring diagrams/instructions.
I am looking at the "Quick Setup for Supra MK-III" in the physical instructions that came with the maft-pro. It tells you to "Tap" (meaning to connect, but keep the stock path - "T" in) all of the wires that you connect except the AirTemp output (brown) and the wideband input/ground. So based on this, how does the maft-pro control anything at all? Is the maft-pro quick setup wrong, or does the maft-pro control things by boosting the signal instead of intercepting and translating?
Also in the "Translator Pro User Manual" it tells you that to splice the MAF signal, yet tells you to tap it in the quick setup.
Then I was reading about the member made wiring diagram and install:
http://www.supramania.com/forums/showthread.php?t=11783&highlight=maft
My interpretation of that is that it is just to show you where to install the wires, but not how (as in tap vs. splice). One might guess that you connect it just like that diagram shows, but obviously you don't since that would mean splicing the ECU power and ground.
I have an 89+ turbo that I have spent a ton of time and money on and I don't want to hastily connect the wiring the wrong way and potentially screw something up.
Pertinent setup info:
89+ turbo, manual
maft-pro with all options, including LC-1 wideband
There must be something simple that I am missing somewhere since a lot of people have this installed now.
Any sort of clarification would help out a ton; thank you!!
89+ turbo, manual
