maft pro general questions
tromspert
86
PA
Hey guys I can't seem to find exactly how I increase fuel and boost after putting new injectors in? What sections would I change?
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
You would actually want to decrease the amount of fuel the ecu can see (if you installed bigger than stock injectors). Once you do that you can increase boost (slowly). What are your mods?
tromspert
86
PA
Ct26 turbo drift motion 57mm, 2jz swap with 7m electronics. Still running the old 440 injectors from the 7m. Maft pro to tune it. Running about 12 lbs of boost. How would I adjust the injectors if I was going to say 550's or larger ones? I was told possibly the main scale although I'm unsure
http://www.supramania.com/forums/sh...s-in-the-making-2JZ-GE-T-START-UP-VID-POST-34
My car before I bought it
Bmettie
188
Florida
Mainscale is what your looking for. That's for gross adjustment across the board, then you'll have to tune with user tunes from there.
tromspert
86
PA
User tunes? Like from other individuals? Or a program?
And as far at main scale so let's say I installed 1000cc injectors, how would it be adjusted? Like a specific number. I'm really lost on that portion. I'm stuck with 440s currently and theyre awful.
Sep 17, 2013
757
San jose
Bmettie;2030368 said:
I'm with this guy, If you're tuning a MAF pro learn to tune it. You'll have a lot more respect from members if you answer a few of your own questions rather than asking everyone else to do it for you. Setting a Mainscale seems fairly basic and shouldn't be your major holdup.
tromspert
86
PA
Somehow I hadn't found that guide yet. That helped tremendously
